what carb should i go with?
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
the engine is in my sig, i have a holley 650DP and a 750VS, i am going to run both of them and see what happens. I didnt know about a 750DP, i know thats a pretty big carb. thanks for any input.
Transmission: 4L80E/4L80E
Any results?
I would think either DP you mention could give you off-the-line WOT bog with the converter you've got. The 750VS should work okay when tuned.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Both can be tuned to work. The 750 VS carb will be smoother
in the long run. They are very forgiving because of the automatic nature of the vaccuum secondaries.
I'd start with the 750vs they are easier to dial in.
Then experiment with the 650 Dp. With different shooters and
pump cams. You'll be a carb guru when you're done.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
