Help With Fuel System
Old Jul 14, 2002 | 04:42 PM
i_alex's Avatar
Car: vistacruisa
Engine: 532
Transmission: mousburgg
Axle/Gears: 4x4
i have a 91 camaro rs, it had a 305 with TBI, i have now put a carb on it and the only problem now is how much psi i need to run, i would like to know if i can put a reg on the line with out blowing a fuel line or messing up my fuel pump. friends say i need to drop the tank and put one on my car off of a carb camaro. any ideas or comments from people that have done this before would be helpful.
Old Jul 15, 2002 | 08:36 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard.
5-7 psi is the "typical" carb pressure range.
Look though posts here,you'll find several people who have used the TBI in-tank electric pump successfully. You should use a 3-port regulator that uses a return line, rather than a simple shut-off-type two-port regulator. The good news is that all 3rd gens had a return line (unless you removed yours in the carb swap).
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Grant2k
Jul 10, 2018 04:01 PM
Fast355
Dec 2, 2016 06:33 PM
beachrodder
Aug 25, 2015 08:05 AM
