vent tube from fuel cell?
what would you guys recomend i do about the vent tube on my new fuel cell? i have never done anything with a fuel cell before so i'm not sure. thanks.
Rich
Rich
well i'm not entering any class of drag racing. just a test n' tune session when i get it all done. the i have it set up to use part of the factory filler neck.....i guess what i should have asked was "how do most of you guys set up your vent system with a fuel cell"
thanks for the reply though.
Rich
Rich
Car: 1970 Tube chassis Camaro
Engine: 632 Big Chief
Transmission: Rossler TH400
Vent it to the outside...
Be sure to coil up the vent line a few times before turning it down to go through the floor. Otherwise, it will siphon fuel when the cell heats up and trys to push fuel out the vent...
Also, be sure to run a ground wire to the metal filler ring on the fuel cell...
Without the ground wire, you run the risk of burning your car to the ground...
1992 Trans Am
May 10, 2023 07:19 PM
