Carb questions
Old Oct 10, 2002 | 02:41 PM
84zeddd's Avatar
Carb questions
I called a place around here who rebuilds carbs,I told them I was
looking for a 750 v.s..They said they have one but it has the choke ground off(so I can`t tell what the part number is)And it
also has 4 corner idle adjustment.I was wondering if this is a
major score or a tempermentel race only piece.Also since it needs
rebuilding he will set it up the way I want.I did a search a search
and came up with this basic combo.#70 primary jets,#78 secondary jets(install my conversion kit to accept jet changes)
The purple seondary spring,and an 8.5hg power valve.Oh yeah
the motor is a 355 sbc 10.5:1 compression.Dart sportsman II
intake and heads,crane H-272 cam,shorty headers,dual exhaust.
Car has 3.73 gears.
Old Oct 10, 2002 | 03:29 PM
Jester's Avatar
Too bad..I'll like to see the list number too. I've never seen a VS carb with a 4 corner idle. Usually thats reserved for Dominators and 4150HPs. I wonder if the used to make them that way..or if it's something the shop added. Either way, 4 corner idle is a good thing. Might not make much difference on your motor, but it won't hurt, and if you ever decide to stick it on a motor with more cam it's really nice to have. Makes getting a big cam to idle alot easier.
If it already has an adjustable idle in the rear, it already takes jets too. You won't have to convert it.
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
