Manual or Electric Fuel Pump???
I am swapping from 305 tpi to 350 Carbed with 600 cfm edelbrock carb. Would you go with the electric fuel pump with regulator or install manual fuel pump? Thanks.
Kevin
Kevin
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I would probably install a regulator on the stock pump. Using a manual pump would make your arm tired in a hurry.
92camaroJoe
Aug 13, 2015 06:07 AM
