What THE CRAP IS THIS??! my holley is WEIRD!
Old Jan 23, 2003 | 05:23 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
My friend buys a 750 Vacuum secondary carb... ok so we open it up to jet it... and we find...
THIS!!!!!!!!!!!
Attached Thumbnails What THE CRAP IS THIS??! my holley is WEIRD!-weirdcarb.jpg
Old Jan 23, 2003 | 06:18 PM
Jester's Avatar
Thats a metering plate. ALot of VS carbs have that.
Old Jan 23, 2003 | 06:42 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
A metering plate? but wheres the jets? how do i change the amount of fuel going into the venturies when the secondaries open? My other 750VS carb doesnt have that thing, it has a metering block...
what should I do?
Old Jan 23, 2003 | 11:25 PM
82camaro's Avatar
Car: 82 camaro SC
If you need to adjust the secondaries, either drill out the metering plate or install the conversion kit.
Old Jan 24, 2003 | 12:36 AM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
now were getting somwhere... whats the conversion kit?
Old Jan 24, 2003 | 05:14 AM
onebadwagon's Avatar
it basically allows you to put a metering block like what is on the primary side, onto the secondary side so you can adjust fuel for the secondaries.
i think its like fifty bucks through summit.
adam
Old Jan 24, 2003 | 09:56 AM
Pony Killer's Avatar
Car: 1986 Z28
Engine: 355
Transmission: th400
the 4160 holley. you can either use different plates for tuning it, or get the conversioin kit the others were talking about.
I prefer having jets in the rear, but the plate system is funcional.
Old Jan 24, 2003 | 12:24 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
<b>but the plate system is funcional.</b>
ok so does this PLATE thing I have, have a number so i can tell what Jet Size worth of fuel it will be adding when the secondaries open up?
Old Jan 24, 2003 | 12:42 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have the same carb. I also was thinking of getting the conversion kit.
Old Jan 24, 2003 | 01:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"4160 to 4150 Conversion Kit", Summit p/n HLY-34-6, $39.95 (add "S" suffix if you want "shiny" rather than chromate finish).
"Holley Jet Assortment Pack", Summit p/n HLY-36-181, 2 ea #64 to #99 jets, $37.95.
Old Jan 24, 2003 | 04:55 PM
Jester's Avatar
Don't bother changing the plates, if you really have to tune it the block conversion is worth it.
But, get a good ways into tuning it first. A good lot of the time the stock plate is close enough that you don't even have to mess with it.
Old Jan 25, 2003 | 02:27 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
okay well I suppose ill either sell it or try it as is. its going onto a 383 with a blower if i keep it...
i dunno if it will be able to keep up?
Old Jan 26, 2003 | 01:16 AM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
its called a metering plate... just get the conversion kit which is a metering block which will give you 2 more idles screws and will let you use jets
Old Jan 27, 2003 | 08:57 AM
five7kid's Avatar
The metering block in the conversion kit does not have idle mixture screws.
Old Jan 31, 2003 | 04:33 PM
Vader's Avatar
I didn't think they were called "idle adjustment screws". I thought they were "idle air bleed adjustments". Then again, I don't know squat about them. My idea of "tuning" a Holley is a quick trip under a Bomag hot pavement roller with the vibration turnned on FULL. (Maybe I'll catch the pavers this spring and try that.) By then I'll probably have acquired an improved design doorstop anyway.
BTW - You can "fool" the metering plates a little with secondary float level adjustment, too. Whatever you do to the secondary jets and/or plate orifices, you need to consider the secondary throttle diaphragm spring rate as well. Damn - Carters are just so much more flexible and easier to tune precisely.
Old Jan 31, 2003 | 06:46 PM
five7kid's Avatar
http://www.holley.com/HiOctn/TechSer...fo/TI-219.html 2nd paragraph, 1st sentence:
"Most Holley Street Performance, O.E. Muscle Car, Competition and Pro-Series HP carburetors utilize idle mixture screws, located on the sides of the primary metering block." (emphasis added)
Old Jan 31, 2003 | 07:41 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
ah, i sold it on ebay for $202. what the heck right?
i already have a good carb anyways...
hehe thanks for the help tho guys.
Old Jan 31, 2003 | 10:40 PM
Vader's Avatar
Okay, I bit the bait. I was laughing all the way in, thinking it was going to be something like "The tuner has to have more intelligence than the die casting" or something like that.
I've got quite a few of the older BBCs to run with Holley 4150s and a few Fords with mechanical secondaries, but like I said, I don't stay current on them. I alway understood the old factory 4150s on BBCs had idle air bleed adjustments, not strictly liquid fuel metering (like most real carburetors) or mixture volume controls, as the instructions imply.
Told you I don't know squat about them. I rather like the old updrafts and mechanical injection systems, or EFI, but not much in between. Hell, a fat wick in a jar of gas is about all I can handle some days. That might explain a lot of my tuning issues. Naaaahh.
Old Feb 1, 2003 | 11:07 PM
five7kid's Avatar
There is a consistent retelling of a myth that on Holley idle mixture screws, "in" is rich, "out" is lean.
Maybe in some time gone by, but not today.
Hey, welcome to the fuky world of old-time technology with new-fangled twists.
"Third generation F-body - the first muscle car with a brain."
Think that'd fly?
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
