Distributor for TPI to carb Swap
Old Feb 20, 2003 | 05:35 PM
TAsRBAD's Avatar
I switched my car from TPI to carb and I need a HEI distributor That will work with the carb intake. Does any body know what car and year a could get one for that would work.
Old Feb 20, 2003 | 05:56 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Basically any Chevy engine from '75-CC era (early '80's, no 3rd gens except Canadian, and even some 2nd gens were CC).
Let me recommend another course. Factory HEI's are weak above about 4800 RPMs, so the coil and module should be replaced with aftermarket parts. That's about $90-100 there. You'll need a new cap and rotor, another $30 or so. HEIs have been know to lose the magnetism in the trigger wheel, amoung other little "issues". They don't have the best advance curve, and the vacuum advance can go bad or not be quite right for you.
Rather than deal with all that, go to Summit and get a new HEI from one of their several offerings. All of those issues will have already been addressed for about $160.
Old Feb 22, 2003 | 07:24 PM
Homer's Avatar
Car: 1991 RS
Engine: 305 TBI
What's a trigger wheel? Is it the same as a pickup coil? My car quit running about a week ago, and I'm not convinced it's the carb's fault. I can't afford a whole new distributor so I'd like to know which parts of the ignition can go bad, and track them down one by one. I put in a cap and rotor a few days ago and that didn't cure it. Btw, it's an external coil HEI.
Old Feb 24, 2003 | 11:42 AM
five7kid's Avatar
The trigger wheel is the passing that the pick-up coil picks up.
The pick-up coil, control module, and coil are the typical culprits. The trigger wheel can also go bad.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
Sanjay
Aug 12, 2015 03:41 PM
