Think im going carb
Car: 1990 RS
Transmission: TH-350
Think im going carb
i been tossing the idea around to switching to a carb on my 88 formula, my tpi has been hell to deal for months now. i am looking for cheap and easy power. this car will also be my daily driver. i put about 10 miles on it a day. here is what i am thinking...i have a 22K mile L98 backed by a T-5. if i put pro-topline vortec style heads with a comp 274 xe cam, what carb should i use? how much is the vortec style intake gonna run me? i am going to use the mallory 3 port reg and a summit hei distributor. while i am at it i am going to throw on my headers that have been sitting for months due to my tpi saga. what kinda power do you think can be made with this combo and what kinda times? is drivability going to be a prob with that cam? it is a daily driver. i am not really concerned about gas mileage, i am looking for a setup that can be worked on and cheap and easy to maintain. how much is a complete tpi setup worth? thanks in advance guys and all opinions are welcome.
Transmission: 4L80E/4L80E
Re: Think im going carb
Car: '82 Z28
Mmmmm 750 Speed Demon
Just picked this one up today from a friend... New in the box with the Barry Grant dual feed fuel line kit for 350 bucks
Going on my new engine whenever that gets done.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Originally posted by ontogenesis
i'm going the other way, i'm sick of carbs, too much work
What kind of carb were you running? And what kind of problems have you had?
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
i'm right between champaign and kankakee
i had/have a 650 edelbrock, factory reman, electric choke is a joke, didn't work when i got it, out of warranty before i realized it. No one around here works with edelbrock carbs, i had a guy with a spitzer rail tell me he couldn't help me out tuning the carb because it wasn't a holley...my gas mileage blew, i was getting 4-6mpg on a really good day. It ran either really rich or really lean, no matter what metering rods or jets i used. there was horrible throttle response. because of the electric choke not working, and my lack of knowledge about the secondary choke lockout, my carb was running with only the primaries (not bitchin, i still ran 14.6 with a slipping trans). When i finally got the secondaries to open the car ran REALLY lean, all the time. Then the trans let go all together and i hauled it home, put it in the garage, swapped the trans and bought tpi stuff for an lt1 manifold conversion and i'm waiting for it to get warm enough to put it on...
i doubt i will ever go back to carb. I'm not saying some of my problems weren't my own fault, i'm just saying that for me, carbs are way too unprecise, it always seemed like anything the car did, there could be ten things in the carb that could have caused it. FI, i hope, will take some of the trial and error out of tuning it.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
