mallory 3 port what is what?
Old Mar 17, 2003 | 06:28 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
I just bought a mallory 3 port off the internet and I can't tell which port is which? It's not marked. All I know is that the thing has 4 ports around in a circle, one port on the bottom of the thing and one 1/8" fitting that i'm assuming is for fuel pressure. Anyone have mallory instructions or can figure this out for me?
Which one is bypass and how can you tell?
Thanks again
Steve
Old Mar 17, 2003 | 06:47 PM
xpndbl3's Avatar
Car: 1984 Z28
ok i was flipping around online and this is what i found ........is this info correct??
Well, it says the bottom port is the return, all four corners are inlet and outlet, in whatever way I want(i'm only using one in, and 2 outs(nitrous and carb), I'll block off the other port, and finally that little 1/8" port is actually for vacuum, or boost, so i won't need to hook anything up to it....
sounds about right? or was that wrong?
Old Mar 17, 2003 | 10:47 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
That's how I have mine hooked up, bottom is return, vacuum thing plugged. Seems to work fine.
Old Mar 17, 2003 | 10:56 PM
xpndbl3's Avatar
Car: 1984 Z28
ok that's what i figured, thanks for checking though
Steve
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
2012sergen11
Oct 13, 2015 07:38 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
