Which carb float
Old Mar 31, 2003 | 05:49 AM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Which carb float
What is the differences between the brass float and the nitrolphyl float? Which one is better?
thanks,
phil
Old Mar 31, 2003 | 09:19 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
nitrolphyl floats are made to withstand alcohol and boost pressure.
Unless you run a blow-through boost setup or methanol as fuel then you don't really need them.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
