anybody with an edelbrock please help me
Car: 85 trans am
Engine: 79 4 bolt 350
i just got the right detent cable for my transmission adn its not fitting right, i have a tv cable corrector from sonax racing that bolts to the carb but what should i do about the bracket? the detent cable is is going at an angle to the carb, what do you guys have for the bracket? where you got it and prices would be great. thanks
I got a my bracket from jegs, pn was 890-376700.
If the pn dont work just type in tv bracket at the search. I did have a problem with my throttle cable though i had to fabricate the bracket a little because the throttle wouldnt open 100%, the tv cable was perfect though. hope this helps.
Car: 85 trans am
does that look anything like the spectre adjustable throttle cable bracket? i didnt see a picture of it. summit has the spectre one for 9.50, its part number SPE-2428
http://store.summitracing.com/defaul...&part=spe-2428
it sais its adjustable and fits all 2 adn 4 barrel carbs, does anybody have any pictures of the linkage on their carbs so i can get a good idea of what it should look like?
It is similar but it is not ajustable like the spectre one. for that price you cant go wrong pick it up. The adjustable one would be better anyway, so you wont have the problem i had with the throttle not opening all the way. good luck.
Pac J
May 17, 2020 10:44 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
