Is this possible?
Old Apr 17, 2003 | 07:04 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Is this possible?
An engine builder told me that if I use carb with a choke with certain cams that it can foul the plugs..Any truth to this..
Anybody here use a carb with no choke for a daily driver(spring to fall)?
Daz
Old Apr 17, 2003 | 08:56 PM
bad84z's Avatar
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
The choke on my edelbrock 750 is not hooked up. Been like that for every since I have had it. Not bad, just in the winter time, I have to sit in it and keep it at about 2,000 rpm's for a minute or so, so it will get warmed up enough to idle and finish warming up.
Old Apr 17, 2003 | 11:56 PM
Jester's Avatar
A badly adjusted or non functioning choke can foul plugs on any motor...regardless of cam.
Old Apr 18, 2003 | 02:02 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
but would there be an instance when a properly adjusted choke will foul the plugs because of cam profile/characteristics?
just trying to undertand the relationship between cam profiles,idla and choke..thanks
Daz
Old Apr 18, 2003 | 06:35 PM
Jester's Avatar
Idle vacuum has a direct effect on choke function. A choke functions by making the venturi see idle vacuum, thus sucking out extra fuel to combat the lean cold carb problem. A really small high vacuum cam will make a motor run richer while choked...but obviously even peanut cams don't create a problem. Larger cams will decrease choke effectivness.....but that will make it lean while cold not rich.
Old Apr 18, 2003 | 09:33 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
great!!! that answered my question!!
Daz
