holley vacume ports
Car: '84 Z28
Transmission: th2004r
holley vacume ports
i have a holley carb that i just got used for free. its a 600cfm vacume secondary, non double pumper with electric choke. i only see one large vacume port that i assume you would have to use that for the brakes unless you went directly from the manifold. is that for brakes or the pcv valve? if it is for brakes, where is the pcv valve port? is that a small one?
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
