is 18" of vacuum noramal
Old May 4, 2003 | 08:13 AM
mypurple92rs's Avatar
Car: 86 iroc
Engine: 350 carbed
Transmission: t5
new to carbs so someone told me to buy abook about them sounds like a good idea I thought.having a eldbrock i was told to buy a book on carter carbs seeing how there pretty much the same.In there they wrote use a vacuum gauge when tuning the carb well i went out and bought a gauge hooked it up at it was running 16.5-18 bounce back and forth <-- is this normal also
btw it's a 350 with a eldbrock 750,rpm intake,2.02/1.60 heads
mild cam can't remeber the duration and it was idealing at about 900 RPM
Old May 4, 2003 | 08:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
For a near-stock cam, yes. The bouncing is not normal; that usually indicates a cyl with a poorly sealing intake valve, or an ignition miss.
Old May 4, 2003 | 09:53 AM
Mark W. Winning's Avatar
I wish I saw 18 inches of vacuum. I am lucky to see 10 at idle.
Damn CC Extreme (lack of) Energy cams!
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
