TPI to Carb
Old May 12, 2003 | 06:36 PM
BFDPerformance's Avatar
TPI to Carb
Ok guys.....first of all has anyone ever done this.....if so can you list every little thing I need to do to make this successful....i know i need a pressure regulator and a new distributor and igniton....can anyone give suggestions as to what kind of ignition and distributor I need....part numbers would be awesome....im running a 350 TPI right now but Im having problems and dont want to dick with it....also will all the lights work without the computer connected....and what do i need to hook the wires from the aftermarket ignition to.....never done one before....im really lost in doing this so all the little details are great.....thanks in advance guys! -Don
Old May 12, 2003 | 06:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://5finger.8m.com/tpi2carb/tpi2carb.html
Old May 12, 2003 | 07:05 PM
Thanks five7 but he doesnt mention anything about the fuel pump.....this is what im most worried about....
Old May 13, 2003 | 08:49 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
You can use the Mallory afpr like you said in our other post. Should be fine. I had to have new fittings for the hoses crimped on. You will have to hook the fuel pump relay up to a 12v source.
Your lights and everything should work fine. If you have duel fans, you will have to hook them up. I am only running one fan and having no problems.
as far as the dist goes. If you get a non computer controlled dist, you can use the Big pink wire and the white wire that goes to the TPI coil. The Pink wire goes to the 12v side of the new dist and the white wire goes to the tach side. Simple enough.
Wait untill you get everthing hooked up before cutting wires. Make sure everything is working and then cut what is not hooked up.
hope this helps. I know I didnt go over everything. Let me know if you need any help.
later
wayne
Old May 15, 2003 | 08:31 AM
Z383's Avatar
how do you identify the fuel relay.. there are about three of them on the firewall.
Old May 15, 2003 | 09:20 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Depends on what year model.
I checked the wiring diagram for my car. I think it had a Green with white stripe, Orange and a brown wire. The other wires were the same color as the other relays. I put 12v to the Green wire with the white stripe. May be different on your car.
Like I said, Depends on the year model.
Old Jun 18, 2003 | 02:27 AM
x5finger's Avatar
Check the website again. Right below the 86 vs 87 manifold pickture. Whole paragraph on the fuel pump.
However, some of that info is innacurate! I removed the ECM on that car, and returned the fuel pump relay to stock wiring. The oil pressure sensor activates the fuel pump once it sees oil pressure. And with this setup, the pump won't keep going if you crash (potentially very dangerous).
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
theurge
Aug 21, 2015 12:46 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
