Fuel pump question
Old May 24, 2003 | 02:39 PM
FstBrd6point3's Avatar
Fuel pump question
I have an 87 383 TPI that I want to put a carb on. I am going to be getting the performer RPM manifold with the Holley street Avenger 770 carb. MY question is, if there a fuel pressure regulator I can buy that will make use of the elctric fuel pump I already have?? I have been told that I can still use that pump. All I have been able to find so far are regulators that just have in in line and dual out lines for a dual feed carb. Is there a regulator anyone knows of that has a return line so send the extra fuel back to the tank??? I have a feeling I will just flood the damn thing with no return..... or am I going to be stuck with having to drop the tank and get a mechanical pump???
Old May 24, 2003 | 09:00 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If you use the factory pump then you have to have a return line.
You can do it that way but eventually you'll be sorry you did... it's just a matter of time.
I suggest installing a pump that will match the carburetor.
Old May 25, 2003 | 11:32 AM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
You can use Mallory #4309 with the stock TPI pump for the time being.And yes I would recoomend eventually to get a pump suited for a carb application.
Old May 25, 2003 | 12:10 PM
1QWIKZ's Avatar
Car: 88 Camaro
Engine: 355
Transmission: TH-350
That is the reg that I ran for years when I first swapped to carb and never had a problem but of course as time went by I was goin faster and the stock lines weren't enough......But for a quick fix to get you back on the road that is the way to go.
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
