Stripped Bolt Holes on Holley 670 SA
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I overtightened a couple of the bolts that hold the fuel bowls on my 670 SA. They stripped out. I want to heli-coil the bolt holes but the bolts have sort of a wierd thread size.
At first I thought they bolts had 1/4 20 threads but it turns out it it's something like 24 - 12 . Anyway it's very close to 1/4 20.
If I use a 1/4 20 heli coil kit should I try to reuse the original bolts even though the thread is slightly differant or should I try to find 1/4 20 bolts of the same length?
Also, Has anyone ever use a heli coil kit? Any tips or things to keep in mind?
Thanks.
Thanks.
Car: 4
Engine: 6
Transmission: 5
You should use the right size Heli-Coil, which is NOT ¼"-20.
Your original guess was correct, the size is #12-24. You can get the kit from NAPA or a real bolt & screw place.
I happen to have one, for exactly that purpose.
About the only tips I can think of, is don't screw up while you're doing it; once you hose a hole that way, the casting is pretty much trash. And be careful if it's a throttle-plate to main-body screw, some of those are very close to the outer edge of the casting, and the casting is prone to crack around the screw hole.
Car: '94 Corvette
If you can't find the parts locally;
Holley
Part #26-3 - Heli-Coil Inserts
Part #26-2 -Installation Tool Kit
Obviously your not the first to do this, it they have part numbers for this situation.
The instalation tool kit is on the very pricey side @ 68 bucks, and the heli inserts are 17 bucks. You can get them from Summit.
Ron
Holley
Ron
I got the #12-24 kit. It was expensive at $45. It was worth it. Three of the eight fuel bowl bolt holes were stripped. The helicoils were a good fix. Now I'll just snug them up to keep from stripping them again.
Car: '94 Corvette
The absolute best & consistant way is using an inch pound torque wrench.
I like about 20-22in# w/Vasoline on the float bowl screws...
Ron
Ron
evilstuie
Jan 9, 2020 08:29 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
