fuel pump
Car: 84 berlinetta
Engine: 383
Transmission: 700-R4
fuel pump
i have a 84 camaro with a carb and am swaping my 305 with a rebuilt 383. the new cam will not allow for the mechanical fuel pump to work so i am going to install an electric fuel pump by the gas tank. do i use the vapor line as the return line for the fuel pump? if anyone has installed an electric fuel pump i would like your input.
Transmission: 4L80E/4L80E
Your car should already have a real return line. I haven't installed an electric pump on my Camaro personally, but all you should have to do is install the electric like you said, and I'm assuming you're using a 3-port regulator with return, plumb the return into the existing 5/16" return line (the supply line is 3/8"). Leave the vapor line as a vent to the evap canister.
I almost bought a 350 shortblock (I believe it was an LT1) at a swap meet last year. I decided against it because it didn't have the mechanical pump provision machined. I could kick myself now.
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
