Need help picking a fuel pump
Old Aug 16, 2003 | 06:33 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
Transmission: 700R-4
I'm switching my 383 from tpi to carb and just sold all my TPI stuff. Now I'm ready to buy the carb setup, but I need help picking a fuel pump. I've been looking at the holley blue, I'm thinking of running 2 pumps one for the motor and one for nitrous. I guess if I ran the same pump I could swap them over if one went out. Does anyone know how to plumb 2 pumps into the fuel tank. A guy at work suggested welding a sump onto the bottom of the tank and plumbing the 2 outlets and 2 return fittings in there. What kind of fittings do I need? Should I replace the stock fuel line? If you guys have any pics or diagrams of a good setup let me know. Thanks in advance.
Old Aug 16, 2003 | 07:19 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I use two pumps on my camaro as you described. I like Carter electrics because they are cheap and reliable.
Old Aug 16, 2003 | 11:35 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
What is the rating on those pumps and where did you get them? How did you plumb them into your tank? I had TPI so I need a new pickup if I go through the top of the tank, what did you use?
Old Aug 16, 2003 | 11:44 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I removed the intank pump and added an aluminum pickup tube inside the tank. Later on I'm going to make my own tank and have a sump with two 1/2" outlets.
Old Aug 17, 2003 | 11:40 AM
firbird's Avatar
is that a glass filter under ur car?
Old Aug 17, 2003 | 06:30 PM
TOXIC-Z's Avatar
Car: 1988 IROC
Engine: 383
hey 305sbc where'd you get the aluminum pickup at?
Old Aug 18, 2003 | 10:44 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I just made it by attaching a section of 1/2" aluminum fuel line to where the factory fuel pump attached. I bent it so that it goes towards the rear of the tank.
It will all be replaced with a sumped fuel cell in time but it works for now.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
