which way should I go?
One of the fittings on the fuel line that runs from the fuel pump to the carb is almost stripped. I am wanting to change it out. Should I stay with the steel line, or get one of the rubber lines ( I think its from Spectre) with the stanless steel cover around it? If so the rubber line , please show pic of how you routed it, if different from steel line.
