tpi fuel pump to carb?
Old Aug 26, 2003 | 12:19 PM
jhperformance's Avatar
I am going to swap the tpi for a carb on my vette motor. Should I run a pressure regulator between my existing in tank fuel pump to the new carb setup? Should I just pull the intank pump and run a rail pump like a walbro or holley? If so, is it hard to get the fuel tank out of an 86 iroc z with the rear end being directly under it?
Old Aug 27, 2003 | 07:53 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
I have an 86 also and I will say those tanks are a pain to get out if your doing it by yourself. I would just go buy a Mallory 3 port regulator and put on it on. Make sure you regulate the fuel pressure to about 61/2 to 71/2 pounds before you start the engine.
Frozer!!!
Jan 19, 2024 04:55 PM
Grant2k
Jul 10, 2018 04:01 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
