Carb/Intake question...
I recently purchased an original, rebuilt 305 for my 86 T/A. Question is what would be a good intake and carb setup for this mild engine. (My drag racing days are long gone) Looking for a good daily driver with some throttle response. Any help would be appreciated........
P.S. Got an excellent deal on the net for the engine
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Do you still have the ECM in yours?
I have an 87 Z38 with the LG4 motor & disconnected the ECM completely.
I went with the Edelbrock 2104 Performer, Holley 4160 600 CFM carb, Accel Dist & coil, & everything works great.
I'm not sure about the 86 model, but on the 87, I had to exchange the Edelbrock intake for the one they gave me at first as the center bolts are at a slightly different angle than the rest.
I have not really got on it but it feels lots better than the older computer assist carb & I still have the factory exhaust including exhaust manifolds.
Car: 1984 Z/28 Camaro
Engine: 350ci
Axle/Gears: 9" 3.73 spool
similar questions i have
i have similar debate, i have decided to get the edelbrock 1406 and 2101 dual plane manifold, when i pu tthese on what kind of diferences can i expect for the computer hookups, between the lg4 rotchester and the edelbrock?
i hope it works im gonna try and install on friday, saturday, and sunday, girl friend wants my car running
simply put, if you pull the quad off the motor you will have to totally unhook the computer, there are no aftermarket carbs that have computer hook-ups. if you go with the edle. you will need to get a non-cc distributor and if you have a 700R4 tranny you will need to find a way to lockup the converter.
Transmission: 4L80E/4L80E
Don't waste money on aftermarket carb & distributor for a daily driver.
If a Holley, Demon, Edelbrock, non-CC q-jet, and CC q-jet were all sitting on the shelf with all the required supporting equipment available, at no cost to you regardless of which one you chose, the best choice for a daily driver would be the CC q-jet.
The best manifold for any of them would be a Weiand Action+ EGR or GMPP q-jet EGR. But, assuming you don't have one of those on the shelf above, the factory aluminum intake manifold is just fine for the stated use and desired results.
Put your money into exhaust, ignition coil & module, and air cleaner upgrades. Cam upgrade wouldn't hurt, but don't have any idea what your rebuild has in it.
