Installing Electric Fuel pump
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
I am installing a (pusher) Carter Electric Fuel pump back by the gas tank. Per some of the recommendations on this board I am mounting it against the sloped part of the uni-body that is actually behind the rear seats. My question is how vertical does the pump need to be? The mounting bracket is 90 degrees which makes the fuel pump at the same slope as the uni-body. Is the good enough?
thanks,
phil
thanks,
phil
92camaroJoe
Aug 13, 2015 06:07 AM
82, camaro, carburetor, carter, electric, fuel, gen, install, installing, mounting, orientation, pump
