Hood clearance
Old Oct 10, 2003 | 02:43 PM
84zeddd's Avatar
Hood clearance
Anyone running a Sportsman II intake,Holley carb and 3 inch
filter under a stock Camaro hood?
Old Oct 12, 2003 | 12:27 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
dunno if this will help. im running a performer manifold with a holley 670 s/a with a 1 inch spacer and a 14x3 filter. just cleared the hood.
Old Oct 12, 2003 | 09:58 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
My holley street avenger, and the holley street dominator inatke (idle-7200 the tall one) would barely fit under my hood with a 3'' element and drop base....
I got all kinds of room now
Old Oct 13, 2003 | 03:37 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If the Sportsman II intake manifold is the same height as the Edelbrock Performer RPM it will fit with the right drop base air cleaner. Get the carb pad height specs from the manufacturer.
The right drop base air cleaner is the ones that were origional
on late 60's chevy muscle cars.
You can buy the aircleaner ***. or just the base from
GM drop base aircleaners Among other restoration parts sources.
They were auctioning some on Ebay.
These air cleaners provide more clearance than the common aftermarket 14" drop base aircleaners.
If you use it with a aftermarket holley carb with a tall(er) choke horn than the old OEM factory holleys of the era you'll need to cut down or remove the choke horn to get the proper airflow into the carb.
Edelbrock carbs don't have this problem but will need a 3/8" thick carb horn spacer to fit the GM base. (Edelbrock catalog)
Here is a pic of the setup on a Firebird. It fits wityh some room to spare.
Old Oct 13, 2003 | 03:47 PM
F-BIRD'88's Avatar
If you already have the intake you can measure the carb pad height specs like this and compare the the Edelbrock RPM specs.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
