took my car to performance shop
Old Nov 6, 2003 | 06:54 AM
icebird_1981's Avatar
i took my car to strate line racing to have it tuneing and install and new egnition system. anyway today i was takeing a look at the eninge and i found that they disconnected my vacuume advance and pulgged all the holes. i cant figure out y they would do this, should i give them a call and ask whats up with that or is this a common thing for built engines???
Old Nov 6, 2003 | 11:26 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
They may have had to if you did not have an adjustable vacuum advance unit. If yours was just stock then you might want to replace it with an adjustable unit and hook it back up.
A performance timing curve plus a factory vacuum advance would just be too much advance in some cases.
Old Nov 6, 2003 | 11:29 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
a common thing for drag racers to do is to use and setup only mechanical advance, and disconnect the vac advance..
its fine in race cars, but its not the best thing for street performance... kinda hurts your gas miliage...
IROCZ1989
Jan 24, 2016 03:55 PM
TheExaminer
Aug 26, 2015 04:59 PM
NBrehm
Aug 25, 2015 11:49 PM
kah992
Aug 19, 2015 02:55 PM
novaderrik
Aug 10, 2015 12:44 PM
