when do the stock fuel lines become a restriction?
Transmission: 4L80E/4L80E
A good mechanical pump on the engine will feed that through a 3/8" line. A good pusher electric back by the tank will easily feed 500 HP through a 3/8" line.
I don't have any problem with 3/8" line & the 396 in my '57, which is putting out an easy 400 HP.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
i found that my fuel pressure would drop around higher RPMS through my factory lines with an holley blue pump when my motor was about 450 HP last year(nitrous included). This year I switched to two holley blues and a sumped gas tank with 1/2in line for my future motor plans this winter. Hope this helps.
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
