Vortec Performer Intake and cable bracket for Qjet
Old Jan 17, 2004 | 06:55 PM
87Formula4bbl's Avatar
Car: '87 Formula
In case anyone ever searches for it, you can use your existing bracket for the Vortec Performer intake. It was pretty easy to modify to fit, and only took about 10 minutes to get it right. Basically all that needs done is to bent the back mounting location out and in as shown in the picture. You'll have to do many small bends, one at a time and test for fitment, but it will fit if bent right. Nothing was done to the front part, it cleared the runner (barely) and the cables are in alignment with the carb. Oh, where the bracket mounts (at the front coil mount hole), I had to use about a 1/4 inch spacer using 2 washers to bring the front part to clear the runner.
In the pic it looks like its not aligned. It only takes the slightest effort to align the two holes and slide the bolt in.
Bottom line: I'm glad I didnt have to butcher it to get it to work.
Attached Thumbnails Vortec Performer Intake and cable bracket for Qjet-1.jpg
Old Jan 17, 2004 | 06:56 PM
Car: '87 Formula
Side pic
Attached Thumbnails Vortec Performer Intake and cable bracket for Qjet-2.jpg
Old Jan 25, 2004 | 10:25 AM
Car: '87 Formula
Updated...
Well, I got the intake on the car yesterday and found that the bracket needed a little modifying to fit the valve covers on. All I had to do was grind a little bit of the lower rear corner off and repaint it, and it works great! Still easy to do.
Old Jan 30, 2004 | 09:29 AM
Barry85Iroc's Avatar
Car: 1985 IROC Z-28
Engine: 355
Transmission: TH-350
Axle/Gears: 3:73
Looks just like mine!
9192camaro
16
Feb 3, 2019 12:21 AM
Fast355
Dec 2, 2016 06:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Genopsyde
Nov 11, 2015 10:46 PM
86IROC112
Aug 17, 2015 02:00 PM
