holley help
Old Jan 25, 2004 | 02:16 PM
geez28's Avatar
Car: camaro z28
Engine: 5 litre
Transmission: standard
holley help
how do I adjust my float level on my holley 600 vac sec.there is fuel dripping into secondaries from the jet visible from the top of the carb,I suspect float level,are the large screws with locking nuts the adjusters and the screws on the side of the bowls the level plugs?any help would be appreciated thanks
Old Jan 25, 2004 | 04:58 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Yes. You remove the site plug (the cap screw on the side).
With the engine running, you loosen the screw first (jam screw), then rotate the nut (adjusting nut) until the fuel just barely stops trickling out of the site plug.
Tighten the set screw, shut off the car, and replace the site plug.
DO NOT set it with the fuel trickling out of the site plug. I've heard many people who think that's right, but in general it isn't.
If it's done that way, it requires the float to drop that much more to get the fuel to fill the bowl again.
BTW, it sounds as if the needle and seat are dirty and not closing the valve. You should probably pull off the rear bowl and clean it. Common problem with Holleys.
Old Jan 26, 2004 | 03:38 PM
geez28's Avatar
Car: camaro z28
Engine: 5 litre
thanks for the help,I`ll try it this week end,weather permitting
Old Jan 26, 2004 | 08:14 PM
firbird's Avatar
also make sure your on some what level ground seen alot of things and one thing i see people dont really pay much attention to.
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
