Edelbrock 1406 Conversion
Car: 1983 G20 Van
Engine: 305 4bbl
Transmission: Possesed 700r4
Need info on going to 1406 edelbrock from non cc q-jet. What will I need other than the carb and adapter. How do I get the kickdown for the 700r4 right with the edelbrock. Also can I just cut the originol steel q-jet line and run rubber line and filter to the carb. ( I am going to bend and flare steel line so that the rubber will only be a temporary solution) Also does the edelbrock have an internal filter (like the q-jet) or does it need an external inline type. Also how will the 1406 compare to my (bogging 10mpg) q-jet in mileage, performance, etc.
Car: 1986 Irocz
Axle/Gears: 3.25:1
Tab-F is for the TV cable.
Yes you will need an additional filter because it only has a screen inside the fuel inlet.
The 1406 is a good choice. They can give super response and it's rare to find an engine that one will bog on.
Car: 1987 ta
Engine: 355
Transmission: t 5
you will need an angle adptor if using a drop air filter, you may need a adptor for throtle cable and kick down. the one supplyed is for older gm cars.
Pac J
May 17, 2020 10:44 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
