electric choke
Old Jan 28, 2004 | 05:54 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
Transmission: 700R4 Overdrive
electric choke
I have a 1986 T/A witha 4 barrel carb with an electric choke. I would like to know where is the relay for the choke. I put my test light on it and its dim but when i then connect it to the choke the light goes of so i ended running a stright line from the battery and it works fine. so im thinking there is a short somewhere. had anyone ran into this problem before?
Old Jan 28, 2004 | 07:29 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Was the engine running when you did this test light thing, or did you just have the ignition on?
Did you disconnect the wire from the choke thermostat when you put the test light to the circuit?
Old Jan 28, 2004 | 08:22 PM
Biggwinn's Avatar
Car: 1986 Trans Am
Engine: 305 Carb
electric choke
no the engine was not running , but i have done in the past and the same thing happenci.clamp the wire back to the choke the dash light will come on inside while its running. Put the test light to it and the test light will go off. its like not enough juice is comming through
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
lanceflame44
Sep 25, 2015 12:28 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
