What carb/intake should I use?
Old Feb 3, 2004 | 08:18 AM
thirdgencompta's Avatar
I have a 355 with 64cc heads, 1.94/1.50 valves. Compression is about 10.2:1. The block is a 1969 and the heads are from my 88GTA (centerbolt.) I have a hydraulic .464" lift cam with .226/.226 duration at .050. Also using 1.5 ratio harland sharp roller rockers. My question is, what would be the best intake/carb combination I can/should use with this engine setup? I was thinking Performer RPM with a Holley 650dp, but I don't think they make performer rpm intakes that fit my centerbolt heads. Any comments are very appreciated.
Old Feb 3, 2004 | 01:58 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Don't waste your money buying an intake designed for centerbolt heads. Buy a regular Performer RPM and elongate the 4 center bolt holes on the intake. As for a carb a 650 would be great but I'd go with a 750 so it gave me room to grow incase you do some more mods.
Old Feb 3, 2004 | 03:17 PM
I thought about doing that, buying an old intake and using it on my centerbolt heads, but when you say elongate the bolt holes, what do you mean? Cause they go in on a sheity angle, do they make some kind of angled spacer that goes in between the boltheads and the intake??
Old Feb 3, 2004 | 04:45 PM
Car: '89 IROC-Z
Just take a deburr or something and grind the bolt holes so they're (____) shaped instead of (_) shaped. The intake bolt will seat funny against the intake but it doesn't matter because those bolt holes don't go through any water jackets or anything ...they'll seal fine. I've done this on like 3 intakes and have never had a problem.
KCG
Oct 29, 2014 07:04 AM
eca1987
Carburetors
Jan 27, 2012 12:16 PM
Tripper511
Carburetors
30
Oct 1, 2005 05:01 PM
Paul_Ishmyknob
Feb 13, 2003 05:15 PM
Psyte
Carburetors
Apr 22, 2002 09:47 PM
