carb intake on center bolt heads??? HELP
Car: 87 IROC
Engine: L98 5.7L TPI
Axle/Gears: 3:23
ok so i got a 84 trans am with a blown engine and got a 305 out of a 87-92 camaro which has center bolt heads and had a tbi intake on it i want to use the carb setup that i have but the intake will not bolt up right i tried to open the 4 center holes on the intake
but i think i'll be better off will with a different intalke i was looking at the specs and found that some 87's came with 4bbl's but if i found one would the intake work with my engine or should i buy a after market inttake and if so which one???
but i think i'll be better off will with a different intalke i was looking at the specs and found that some 87's came with 4bbl's but if i found one would the intake work with my engine or should i buy a after market inttake and if so which one??? Senior Member
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yes the 87 cars, the L69 and LG4 both had quadrajet 4 bbl carbs and they used the 72 degree intake pattern on the 4 center holes. I know cause a friend gave me an 87 L69 motor to "play" with and take apart for grins.Both weiand and edelbrock make manifolds for these heads, and a 4 bbl carb.
BTW I have a performer RPM and I was able to make it fit my 89 truck motor by elongating the 4 holes.
Car: 87 IROC
Axle/Gears: 3:23
yeah i've been trying to elongate the holes on my intake but i hope i can get it to if not i will have to get a after market you don't want to get rid of the intake off of the 87 engine do you???i need a intake with a egr so the performer wouldn't work
Transmission: 4L80E/4L80E
The Performer is available in '87-up pattern with EGR ( http://store.summitracing.com/partde...art=EDL%2D3706 ).
The Weiand is available in non-EGR only.
Car: 87 IROC
Axle/Gears: 3:23
thanks for the link five7kid but thats a little bit more than i have to spend at this time i was hoping someone might 1 laying around not being used
You could try a "wanted" on the classifieds on this board. But, the '87-up pattern carb was produced a grand total of one year - 1987. That's probably why Edelbrock is so "proud" of their manifold.
(BTW, the last year for the L69 was 1986, at least in 3rd gens).
1992 Trans Am
May 10, 2023 07:19 PM
86IROC112
Aug 17, 2015 02:00 PM
2004, 57, 72, blot, bolt, carburated, carburator, carburetor, center, centerbolt, cinterbolt, deg, fit, heads, intake, quadrajet, work
