difference between pontiac/chevy intake
Old May 26, 2004 | 08:52 AM
2litereater's Avatar
Car: 1984 Trans Am
Transmission: T-5 w/3:73 gears
i am looking to buy a new or used aftermarket intake. does anyone know if i buy a intake for a chevy small block will it fit in on my pontaic are they the same or are they diff. sometimes i see intakes that say for a pontac but usually i see chevy.
Old May 26, 2004 | 09:16 AM
ljnowell's Avatar
If this intake is going on your 84 pontiac, and it has the stock engine (or stock replacement), then you have a chevy engine, dont worry about it. When the bodystyle changed in 82, they used chevy engines in the pontiacs too.
Old May 26, 2004 | 09:39 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Right, you do not have a Pontiac motor. The only Pontiac stuff is trim and stickers on the body.
It's a GM body, if you want to look at it that way; you could just buy it with either Chevy trim as a Camaro, or Pontiac trim as a Firebird. And the only V8 engine that it could be equipped with, from the factory, was a Chevrolet small block. The Pontiac V8 was discontinued after about 81 in ALL body styles.
Old May 26, 2004 | 08:45 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
yeah youve got a "corporate" engine they used them in everything from camaros to firebirds to monte carlos and such ...its a chevy
Jake_92RS
Jan 28, 2020 10:37 PM
masonta
Aug 31, 2015 10:14 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Jake_92RS
Aug 11, 2015 10:39 AM
