rubber fuel line to carb
Old Jun 19, 2004 | 02:32 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Ok right now im running a rubber fuel line because i pinched the line that goes into the carb at the fuel filter my question is ...
i want to convert to a braided line but im cunfuse with all these AN sizes i dont know what that means ...
in short..
what size fittings to i need to connect the braided line to the carb?
...and i guess i need another fitting to connect it to the pump,
what size is that fitting?
stock quadrajet carb, stock fuel pump on the block
Old Jun 19, 2004 | 02:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The an size of the line is multiplied by 1/16" to give the inside diameter of the hose, so -06 AN is 6/16" or 3/8".
Aeroquip has a kit with everything you'll need. P/N FCP0139, comes with 30" of -06 hose, an FBM1012 -06 straight hose end, FBM4032 -06 90 degree hose end, and a pair of FBM2108 adapters for the fuel pump and carb.
The only things you might want to add are some brackets to hold the hose down and keep it from moving around, the external braid is just like a file on anything it rubs against. Try an Aeroquip FCM3484 or check the electrical section at Home Depot or your favorite hardware store for a rubber-lined bracket with about a 5/8" I.D.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
