quick electric choke question
Car: 89 Camaro RS
Engine: 350 carbed now
Transmission: World Class T5
Axle/Gears: Peg Leg w/ 3.73's
Alright I was hooking up all the wiring on my car today and realized I havent wired up the choke on my holley 670 street avenger. I am pretty sure I know how to do it but I wanted to check since its been a while since ive been around a carb. So all i have to do is run the red wire to the positive terminal on the dist. and the black wire to a ground right?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
you DONT want to hook it to the coil wire.
you want the coil wire to use all the energy it can.
run the choke wire into the car... use one of the grommets by the drivers feet. the speedo cable one works fine...
put a male spade connector on and connect it to a ign on power source on the fuse panel.
Car: 89 Camaro RS
Alright guys cool, I new it needed to go to a switched source and now I know not to hook it to the coil. Thanks.
86IROC112
Aug 17, 2015 02:00 PM
