what carb?
Car: 91 Z28
Transmission: 4l60e
what carb?
ok guys im going to be rplacing my carb and was wondering what cfm rating would boost my performance a good bit and not totally kill my gas milage considering this is a daily driver car
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What else is done to the car? If it's stock, I'm afraid changing the carb is money down the drain. That should be one of the last things you change. They can be modified to flow ~750 cfm with crisp throttle response.
Transmission: 4L80E/4L80E
You've already got the right carb. Check out the tech articles (linked on the board home page) for what will make it perform better.
You car is being held back by exhaust, air cleaner, cam, ignition, and heads, in that order. Spend your money there if you want better performance.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
