Mechanical Secondaries
Old Jul 23, 2004 | 08:12 AM
dave86ta's Avatar
Hi, I've got a Rotchester 4barrel and it has mechanical secondaries aposed to vacum ones.
I was wondering if there was away to bypass the sensors and have a switch to activate the secondaries???
Thanx
Dave
Old Jul 23, 2004 | 09:18 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
umm, if its MECHANICAL, there are no sensors.
Old Jul 23, 2004 | 09:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What Rochester 4-barrel is it?
What kind of car is this?
Old Jul 23, 2004 | 12:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
On the Quadrajet (was there another Rochester 4bbl) secondary throttle blade opening is controlled by the throttle arm when the choke is open. Air flow and enrichment in the secondaries however are controlled by the opening of the secondary air valve, which makes it behave more like a vacuum secondary or other demand-based secondary design.
Old Jul 24, 2004 | 08:07 PM
dave86ta's Avatar
Thanks guys,
The Carby is a 780cfm Q-Jet, it's running on a 350chev in an 86 T/A.
I was after a way to have the secondaires open so the car get's to full power quicker when draging & stuff like that , rather than dump the pedal, the car bogs down for a second or 2 while the secondaries open, then takes off
Old Jul 24, 2004 | 08:50 PM
nsimmons's Avatar
try tightening the av flap spring, check the tech articles
Old Jul 24, 2004 | 08:51 PM
Momar's Avatar
The air valve may be adjusted to loose. The air valve is the part that actually controls the air/fuel flow for the secondaries. It is demand based not mechanical. You might want to try tightening up the spring for the air valve. I think that there is a tech article that describes how to do this.
Lbibb
May 5, 2016 12:00 AM
sjorgens
Oct 1, 2015 07:54 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
mfp189
Sep 27, 2015 09:25 AM
