newb with carbs...someone help a lost kid
Old Aug 5, 2004 | 01:19 PM
hiphop's Avatar
Car: Camaro drag car, 98' c1500 vortec 350 for daily driver
Engine: whole bunch of tree fitties
Transmission: same as above
I have just put a frsh 350 into my 91 camaro. I has the stock l03 heads with an lt1 cam (roller motor) an intake that is too big for it (power products hurricane= to victor jr) I know its too big of a manifold but I am building another 350 with high rpm cababilities. This is a race only car and just trying to get this new motor broke in but cant with this damn carb. I have never messed with a holley or any carb for that matter. I have always messed with tpi and tbi so I am kinda being thrown for a new learning curve. I have a 650 holley 4150 series that my dad has had on his 71 nova with a 307. The 307 would run very good and idle good. But I put it on this engine and its hard to start and when I get it to start it runs at about 1200 rpms for 5 to 10 seconds then dies. Whats going on?
The timing was accidentally set at about 4 degrees advanced the first couple of time I tried cranking it causing it to back fire twice through the carb. I dont know if it hurt my power valve or not because I dont know carbs so I dont know where the damn thing even is. Can someone please direct me to something that can tell me how to mess with this damn thing> thanks
HIP HOP
Old Aug 5, 2004 | 02:55 PM
85VortecTA's Avatar
Car: Trans Am
Engine: chevy 350
I am also very new to carbs, traded my TPI for a carbed setup, I learned a coupl of things and please don't take offense I just learned this crap yesterday. you have to push the throttle in a little to have the car start up quick. then once cranked over you have to hold the throttle in a little ways so it could warm up before letting off of the gas or it will die. In my tpi it was turn key and drive, now it a bunch of steps in between lol. guess thats the fun part of being old school..
you might want to toy with the idle mixture screws also.
Old Aug 5, 2004 | 03:32 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
What is the model number of the carb? The number can be found on the air horn, if there is one.
If this is a race only engine, just curious, why does it have a smallish factory cam (for a 350) and swirlie-crap heads? The LT1 cam can be lived with, but the TBI heads, they are far from performance pieces.
Old Aug 5, 2004 | 03:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: newb with carbs...someone help a lost kid
That's not what caused it, 4 degrees is nothing. Double check your plug wires and make sure you have the firing order right.
Jynx88
Oct 4, 2015 08:19 PM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
