Need help getting the idle setting perfect on Holley
Old Sep 10, 2004 | 03:28 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Carb is a Holley 4777-7 650 double pumper and it is jetted right and the engine is timed properly. The car idles fine at 14-15 inches Hg @ 900 rpm. the only problem is that my exhaust smells strong at idle. I have a Vacuum gauge and an A/f ratio gauge.
I would like some input on how to properly adjust idle circuit. I kind of just turn the two screws til it starts to die then I back them off until it sounds fine. Is there a way to do it with a vacuum gauge?
Old Sep 10, 2004 | 03:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Set them for max vacuum; then shut the car off, average teh number of turns from the bottom for both of them, then set it for max vacuum again; if you move the screws much, shut it off and average them again, and reset for max vacuum.
You want the screws the same # of turns out, with max idle vacuum. If you had an auto you'd probably want to do it in gear.
Old Sep 10, 2004 | 03:44 PM
GASGZLR's Avatar
Thanks I will go try that, but what about the gas smell? Is that just the joys of having a carbureted muscle car?
Old Sep 10, 2004 | 04:20 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Hard to say.... go get it set right and see how it is then
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
9192camaro
16
Feb 3, 2019 12:21 AM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86IROC112
Aug 17, 2015 02:00 PM
