warm starting issues
Old Oct 29, 2004 | 10:00 PM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
Axle/Gears: stock/3.42
First off let me state that my cvr mini starter and optima red top have absolutely no problem spinning this engine . Cold,hot,it doesnt matter it spins extremely fast when you turn the key. That being said I have a 600 holley 4160 vac sec. (came on the 350/330 deluxe gmpp) It starts wonderfully when it is cold (sits overnight) But once it warms up, you have to pump the gas 4 or 5 times every time you start it. If it sits 15 minutes or 2 hours you have to pump the gas to get it to start. Is this normal?
I could see hitting the gas once but it just wont start unless you pump it several times. I have the electric pump in the tank with the press. reg adjusted to 6 psi. (it reads a little higher when it is cold but settles @6 once warm) That is the only problem I have with it. No bogs,stumbles or hesitations it runs very well otherwise. Thanks in advance for any input
Old Oct 29, 2004 | 10:14 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
are your fuel lines running anywhere near the exhaust anywhere from the engine back???
and are they running anywhere near the engine block ....such as touching it ....where they would get a vaporization problem at all ??
Old Oct 29, 2004 | 10:54 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The typical carb starting procedures are:
Cold: Give it half a pump, let off completely, start. Sometimes it's a full pump when really cold.
Hot: As you start to turn it over, give it a little bit of gas and hold - don't pump it.
I suspect you're flooding it when warm and it starts in spite of that, finally.
Old Oct 30, 2004 | 07:38 AM
1982z28's Avatar
Car: 1999 Z-28
Transmission: m6
fuel lines are 4-5 inches away from exhaust at closest. So i dont know if that could be the problem or not???
As for starting procedure I will try that this afternoon. This is my first holley. I had a edelbrock 600 and 750 on this car before now and it always started up real easy. Is there any chance thru misadjustment of the carb (A/F, or jetting) it would cause this? Maybe not far enough out to stumble or hesitate but enough to lean it out slightly to where it would need a little more fuel to start? Anyways, I will try the different starting today and let you know
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
86Base
Aug 8, 2015 01:34 PM
mustangman65_79
Aug 8, 2015 12:07 PM
