750dp and 700r4
750dp and 700r4
750 dp and a 700r4??
whats the deal? I hear its not good to run a 750 dp with a 700r4 ?? is this so and why ?? is it the detent cable problem? is there a certain bracket I would need to run ?? help me out here guys...
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
You can run any carb you want with a 700r4, just need to get the right cable bracket-can use the old one if the car was a V-8 carbed before you change carbs, then you just have to get the right adapter sold by holley as a kit that'll hook the detent cable upto the new carb.
Not very hard at all
I woould imagine they'd carry it or can order it.
Car: 86\92 Mutant
Engine: 355CI 430HP
Transmission: T-5 with mods
Axle/Gears: 7.625", Eaton Posi, 3.73
Originally posted by NOSFEDGTA
thanx guys..... can I get the bracket through gm ?
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
