TBI to CARB.
Subscribe
Dec 10, 2004 | 03:12 AM
Is there a custom aftermarket wiring harness that is sold for this swap, or do I just clip the wires that are no longer needed?
I'm wanting the engine compartment to look clean, don't need no loose wires hanging around.
I am going to be stroking my 305 & use Vortec heads.
I'm wanting to get rid of the TBI now and replace it with a carb.
I'm going to be ditching the pollution crap (smog pump, ect., No sniffers or visuals here.).
I am also wanting to keep the air conditioning & cruise control (have a lead right foot).
Is there a paticular bracket for my kickdown & cruise control that would hook up to the Edelbrock carb I am using?
I'm going to list everything that I currently have on my Must Order list for this rebuild. Let me know if I missed anything or if you would change anything.
335 Stroker kit
Vortec Heads Cast #10239906 64cc Chambers 170 int. / 1.94 ext. 1.5 lift (milled 0.20 ~ ported & polished)
Edelbrock non-egr Performer Vortec intake (p/n 2116)
650 cfm Edelbrock Thunder series carb (electric choke p/n 1806)
Mallory HEI Dist. (jegs #650-8548201C)
Mallory HEI coil (jegs #650-29212)
Mallory AFPR (jegs #650-4207)
Fuel preasure gauge (Does this come electric so it can be monitored in the cab?)
Comp high energy cam grind # 268H (p/n 12-210-2)
700R4 TCC lockup switch (p/n 60109 from www.northernautoparts.com)
Painless fan relay kit~ 185* on/170* off (jegs #764-30103)
Edelbrock Proflo Air Cleaner (p/n 1002)
Ofcourse a good set of shorty headers & exaust
Reply 0
Dec 10, 2004 | 04:08 AM
All you need to do is retain the power and tach leads to the distributor, the battery cables to the starter and alternator.
The ecm harness will be seperate (more or less) and run into the right fender. You can just chop the wires, or unplug the harness.
Check into the fan as it may or may not be ecm controlled. I dont know. On my car it was a cc carb originally so it just has a fan switch in the intake manifold.
The previous owner just unplugged everything and left the wires hanging. I removed most of the wiring and then used a pc power supply as a 12v source and tested all the other wires. The power supply works well, if you short something by accident the supply just turns off.
Reply 0
Dec 10, 2004 | 09:25 AM
Quote:
It's supposed to be in the passenger side head. Maybe the previous owner screwed that up, too.
Reply 0
Dec 10, 2004 | 11:23 AM
So if I unglug the ecm wiring all together I will still have control over my A/C & cruise control?
I'm not wanting to to be a screw up chop job.
That is why I came asking before I began ordering stuff. No comments on my list, so I assume it is workable.
Reply 0
Dec 10, 2004 | 03:13 PM
Quote:
You assume too much.
You posted on multiple forums; for this one, your list wasn't really on the table. I replied with my observations on your list on the other forum.
Reply 0
Apr 21, 2005 | 10:40 PM
I'm sure you've been told this but you could save a lot of money on machine work and such by getting a 350 core and having it built or simply buying a 350 shortblock thats already done. As far as the fp gauge any company that makes quality gauges has them, not sure about sun pro and such.
Reply 0
Subscribe
