electric choke
Old Jan 19, 2005 | 11:32 AM
HorseflyDF's Avatar
Car: 86 Camaro Z28
Engine: 350 sbc goodwrench
Transmission: T-5 in the works
Axle/Gears: 10 bolt 3.42 open
electric choke
My problem is the electric choke isnt working
on my holley 2160 series 4 bbl carb.
I checked to see if there was 12volts going to
the choke from the black wire.
There was no power at the wire.
My question is there a fuse for the choke hot wire?
Dave
Old Jan 19, 2005 | 12:58 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Is this the factory wiring?
Was the car running at the time? (not just turned "on", but actually running)
There will not be power there unless the alternator is actually charging.
Old Jan 19, 2005 | 01:43 PM
HorseflyDF's Avatar
Car: 86 Camaro Z28
factory wiring
yes the car was running when I tested the hot wire to the choke
Old Jan 19, 2005 | 03:41 PM
nsimmons's Avatar
Try the choke fuse, my relay went an blew the fuse. So i had to re wire the relay to provide power when the key was on not only charging.
SRKLEGIN
Oct 29, 2015 06:38 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
Saxondale
Carburetors
33
Oct 1, 2015 10:26 AM
lanceflame44
Sep 25, 2015 12:28 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
