Do i need to changed Distributors for carb swap?
Old Feb 27, 2005 | 06:06 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
I currently have a LO3 all stock and im getting ready to do a carb intake cam and possible heads swap. To go to carb do i need a different distributor?
Old Feb 27, 2005 | 07:32 PM
fake formula's Avatar
Car: 1986 z28 camaro
Engine: 305 4bbl
Transmission: t-5
yes, you will need a non computer controlled distributor
the easiest way to go would be to use the older style hei distributers that dont require a computer
Old Feb 28, 2005 | 12:13 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Go here for an EFI to Carb swap:
https://www.thirdgen.org/newdesign/tech/carbswap.shtml
This is the route I will be going if my 454 TBI will not work with the Vortec 350.
Old Mar 1, 2005 | 08:45 PM
Huffs_91_RS's Avatar
Car: 84 Z28
Engine: 383
Axle/Gears: 342 Posi
The page that 86z/92rs is the same one I used. It worked really good. Just have to splice into 2 wires. Its fairly easy.
Old Mar 4, 2005 | 11:45 AM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Jeff, you wouldnt happen to have a spare distributor would ya?
Old Mar 4, 2005 | 06:34 PM
Car: 84 Z28
Engine: 383
Ill check and see. I got the stock one, but it want work. May have one.
Old Mar 7, 2005 | 07:41 AM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
i would look into the Mallory direct replaecent HEI units. They cost about $160.00 are billet and come with all the advance weights you'll ever need. I had my old HEI recurved and rebushed. I like it, but I went back to the Mallory.
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
86IROC112
Aug 17, 2015 02:00 PM
cstrobel65
Aug 15, 2015 10:19 AM
