Hood Clearance
Hood Clearance
I'm putting on an Edelbrock EPS intake and Edelbrock carb how much hood clearance am I going to have for an air cleaner. By the way I'm using the stock 83 cowl hood. If anyone has done something like this and could tell me how much room between the carb and hood it would be appreciated.
Adam
Adam
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
doesn't seem like you're getting any responses. From previous posts, as far as I know you won't have much room at all, you'll need a very deep drop base air cleaner. however i'm not at all familiar with that intake. Perhaps five7kid could move this thread to the engine/general tech forum to get more responses?
Transmission: 4L80E/4L80E
The EPS is the latest version of the Performer. It should end up as the same height as stock. So, a drop base air cleaner is required.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
