Q-Jet questions
Old Apr 14, 2005 | 10:09 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Q-Jet questions
Ok, I posted a question about using my q-jet with an Edel performer intake a few days ago and I have more questions.
On cold start gives extremely high idle and choke doesnt seem to operate correctly, barley opens up. It SHOULD eventually open all the way, right??? Choke releys on 12V to operate right?? Damn thing wont open fully.
I'f I manually open it all the way it causes the engine to die, even with the curb idle screw turned in all the way.
Idle stays high untill the engine is warmer and then if you mash the gas it drops down to about 800-900 RPM is the lowest I can get it to idle in park.
This carb is a reman, and the directions say that nothing needs adjusting but mabey the curb idle.
For extra info, I'm an FI guy and carbs are really confusing but I can learn. I'm using a new edel intake and using NO emisions. I've looked over and over for vac leaks and even changed the carb to intake gasket with no change. I get good fuel pressure.
Thanks in advance
Old Apr 14, 2005 | 10:22 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The choke should open all the way, eventually. If it isn't, then you might not have +12V to the carb, might have sticky linkage, or might have a weak choke coil.
Is this on a CCC Q-jet or a non-computer Qjet?
Old Apr 14, 2005 | 10:43 PM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
Yes, its a CCC Q-jet. Its new, or reman anyway. Even if it opened all the way the engine would not keep an idle. Starting to wonder about these reman carbs.
Old Apr 14, 2005 | 11:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It wouldn't idle when the choke was opened all the way after it was warmed up?
Old Apr 15, 2005 | 05:59 AM
84taowner's Avatar
Car: 1984 T/A
Engine: L69
correct. Thats what has me wondering. And thats even with the curb idle screw turned all the way in.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
