how do i read error codes on an 87 lg4 car?
Old May 9, 2005 | 08:08 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
i know how i used to do it on my 89 tpi car but how do i do it on this car?
it does not have the same 12 pin conector
thanks guys
joe
Old May 9, 2005 | 10:47 PM
85cmroz28's Avatar
Car: 1985 Camaro Z/28
Engine: L69
Axle/Gears: One-Wheel-WOnder 3.08
Just get a short length of wire and jump the A and B pins on the ALDL connector under the steering wheel in the dash(with the ignition switch turned to "on" and not running). The check engine light will flash the error codes. It will always start out with code 12, which is normal. Then, if you have any actual error codes it will flash them. It will cycle through a couple times, always starting with the code 12.
Example: After flashing the code 12, the check engine light flashes twice quickly, then once more. 2 flashes plus 1 delayed flash would make a code 21(Throttle Position Sensor). I hope this helps.
Old May 9, 2005 | 10:49 PM
jerflash's Avatar
i did it like that on my 89 tpi with the 12 pin connector but from what i read because i dont have the 12 pin i may have to do something different
Old May 9, 2005 | 10:53 PM
85cmroz28's Avatar
Engine: L69
It should work the same way, just jump A and B.
specialized
Jun 18, 2022 09:26 AM
RazorN8
Jan 7, 2022 11:44 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
mizz0313
Aug 12, 2015 06:45 AM
