Holley Red Fuel Pump confusion!
Old May 11, 2005 | 04:10 PM
unklechuckles19's Avatar
Car: 1987 Z-28
Engine: 355
Axle/Gears: 10 Bolt/3.23 peg leg :(
mods, feel free to move this if i didnt put it in the right place, i figured this was a good place for it. alright, i just baught a holley red electric fuel pump for my 89 350. i went ot install it today, and after drilling holes for mounting, running the wire i was ready to install. i put the bolts through the holes that came with the package, and tried had it all mounted, but the bolts are tapered at the end, adn the nut only goes on a few turns. why is this? im new at this stuff, and i cant figure it out. i dont want to tighten down the nuts too hard, so i dont strip the threads. i tried to call holley and talk to a tech there, but i tried for an hour, and the line was busy the whole time, so im resorting to you guys. oh, and genious me lost the directions, have NO IDEA where i put them when i opened it the first time. what am i doing wrong? thanks in advance.
Old May 11, 2005 | 10:01 PM
Car: 1987 Z-28
Engine: 355
ttt
Old May 12, 2005 | 08:10 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I suspect the mounting bolts that came with your pump are self tapping tapered bolts. You could buy 1"X 5/16" bolts, washers, and nuts and use them instead.
Old May 17, 2005 | 05:03 PM
thebigwelsh's Avatar
Car: 88 firebird under construction
Engine: 350 with trick flow everything
Transmission: th350
Just tighten em up. They will be fine. Its what i did with mine.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
