Holley Red Fuel Pump Qs
Old Jun 5, 2005 | 02:59 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I bought a Holley red pump, rebuilt from an ebay seller. It was a good deal, so I just bought it to keep on standby, and it didn't have any instructions with it.
Well, I finally ended up using it and it only works for about 5 min then shuts off. Then after it cools for 1/2 hr or so, it works for another 5 min, then shuts off.
I'm just wondering if there's something I did wrong with the wiring? I just connected + and - to it, that's all.
Does anyone have an explanation for this trouble?
Old Jun 6, 2005 | 10:46 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Is there a relay/circuit breaker hooked inline or is it straight to the battery? If one or the other it's possible they are just over heating. I went through numerious cheap relays until I finally bought a $20 Bosch unit that's been great ever since.
If straight to battery/ground possible impeller contamination, remove bottom cover to expose area where impellers are to see if debris is stuck/hindering operation.
Or it's just possible the motor itself if going south, hence buyer getting rid of it touting "rebuilt"...happens all the time.
Old Jun 6, 2005 | 10:51 PM
Car: '85 IROC
Engine: LB9
Thanks IHI
I'll take it apart to see if there's something I can find.
I have a feeling it's the motor.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
92camaroJoe
Aug 13, 2015 06:07 AM
