best carb for zz4
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
best carb for zz4
i was wondering what is the best carb for a zz4 crate motor i have a edelbrock on there now that i borowed from a friend just to get it running.
Transmission: 4L80E/4L80E
Best for what? Daily driving? Autocross? Drag racing?
What does your converter stall at?
Engine: 350 "ZZ4"
best for street driving with the occasional trip to the track.
i could'nt tell ya what stall the converter is i picked up the car a few months ago.
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I am using a Holley Street Avenger, 670cfm, vacuum sec. I think it is the same thing as a 4160 holley.
I ran a best of 13.85 /1.85 60' and can knock down 21mpg on the highway.
Engine: 350 "ZZ4"
what are peoples thoughts on the demon carb for the zz4 crate motor i believe it's a 650.
but i have been reading that alot of people recomend the 750 for the zz4.
Car: 89 RS
Engine: 383 in building process
I'll check around for it later, but I believe that some companies have a Demon carb calibrated specifically for the ZZ4 crate motor. That would be your best bet if you go with Demon.
What induction did your car originally have? Does it still have it?
If it was carb, why not use it? Certainly the best street/performance combo available, carb-wise.
RB's recommendation, then, since street is the primary intended use.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Originally posted by RB83L69
Holley 6210
Holley 6210
2012sergen11
Oct 13, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
Damon
Sep 26, 2015 04:29 PM
350, 670, avenger, brand, carb, carburetor, crate, edelbrock, edlebrock, engine, enginestreet, recommendations, street, works, zz4
